Today’s part seals the objective liner tube to the aperture chamber. I during the machining I already made some modifications to this part, mainly in the detail B the journal for the O-Ring is not practical to machine. So I machined from the back the larger diameter and will machine an extra plug to retain the oring. Also a few changes will be added to reduce machining time.
