High voltage electron gun connector/feedthrough. The threads was a bit of a challenge on the mini lathe since I could not disengage the cross slide. So I had to turn them manually.
A project log for My Custom Scanning Electron Microscope
This is a scanning electron microscope I am building from scratch from mechanical, electronics and control software.
