So I am thinking
1: 3-output signal source each output centered on each of the Glonass bands.
2. Probably some FM sweep of each band +/- a few hundred kHz.
3. A 20W amplifier on each output (let's see what devices we can find that aren't hit by the semiconductor shortage. I used some cheap ones for GSM a while back). Each amp could have a circulator to minimise reverse signals which lead to intermodulation.
4. 3 Separate antennas spaced a few m apart, to minimise coupling and therefore intermodulation. We don't want emissions to overlap GPS or Galileo. Alternaticely a power combiner if we can keep the isolation high enough.
5. Power supply - mains 60W - make it quite flexible say 12V up to 19V DC so you can use old laptop supplies and/or a car battery.
6. A reverse polarity diode just in case, with a warning LED, to make it idiot-proof.
mircemk
Sagar 001
Due to the fact that Ukraine is a former member state of the Soviet union I guess that they share a lot of military technology with the russians. Maybe this device would jam some of their own technology?
