Ancient philosophers proposed that any substance could be made by applying a unique combination of the four elements to the primitive starting material, so called "prima materia". Magnum Opus is the "Great Work" of alchemy to create from prima materia a mythic substance capable of transmuting metals to gold, healing all forms of illness, and achieving immortality.
The Magnum Opus puzzle box uses modern technology to tell the story of the four elements of ancient alchemy. It is fully solar powered and has no internal power storage. It utilizes a custom breakout PCB for the Arduino Pro Mini. The main structure is of laser cut Baltic birch plywood.
