Just some more details about how the Enigma is designed.
You can find the FreeCAD files and STEP files on GrabCAD.
While researching the Enigma it became quite apparent that the machine went through multiple design revisions. Not just the obvious 3 to 4 rotor versions, but also various changes that were mostly likely caused by material shortages during the war. Also there were changes made to make use easier. As a result of the variations available I decided to try to keep the look and feel of the Enigma while using inexpensive parts and simple manufacturing methods, i.e. 3D printing and limited CNC routing/milling.
For the switches I decided to use inexpensive micro switches with custom lever arms. This arrangement allowed me to use consistent keyboard key shafts. You might also notice that I decided to use black resin 3D printed key tops and fill the letter cut outs with white Miliput epoxy putty. They will look very similar to the key tops found on a lot of the Submarine Enigmas, and be a lot easy to manufacture than the brass key tops with letter inserts and glass lenses.
Also I decided to use hex stock for the key shafts to eliminate a lot of parts used for anti rotation. The hex shafts will also allow for easy drilling cross holes for travel stops and spring/switch triggers. Using 3D printing it makes it easy to create the hex holes in both the switch stop plate and the switch cover plate.
For the Lamp panel I designed a circuit board to use E10 sockets to accept the bulbs and make all the common connections much simpler.
Also I plan on using E10 LED bulbs as they should be able to be more than bright enough, run cooler, have a longer life and still be short enough to easily replace the original flat top (squished) incandescent bulbs.
The next major simplification is the patch panel, and the banana jacks and plugs. After exhaustive searching I have found hardware for 2mm and 4mm banana jacks and sockets that can be made to work.
The shorting bar for the patch panel will be a pcboard with a guide block and nylon screws that feed down the barrel of the banana jacks. I will be tapping a piece of brass tubing that will act as the guide and nut for the 2mm banana jack.
The next major piece has to be the Rotors. The first generation rotors were beautiful and complex, so....
I designed the rotor to mimic the rotors used towards the end of the war, very similar to the ones seen in the recovered Submarine 4 rotor Enigmas. As the rotors were all backwards compatible I feel very comfortable they will look good.
My design "just happens" to be much simpler with fewer parts than the early versions of the rotors.
Using 2 pcboards in the design makes it very simple to do the wiring. The input contacts are high current Pogo pins that are very similar in size to the originals. The input pins are soldered to the input pcboard and cross connected with individual wires that can be wired as the various rotors were wired. The input pcboard connects to the output pcboard with smaller Pogo pins. The output contacts are 2.5mm brass standoffs that soldered to the output pcboard and sanded flush to the output contact plate.
t
For the reflector I have elected to use the programmable "D" style, as it could be used on the 4 rotor Submarine Enigmas in place of the 4th rotor and the thin reflector. The "D" reflector even has the D on the case to be visible in the 4th rotor's window. Using the "D" reflector in a three rotor Enigma essentially make's it the equivalent of the 4 rotor variation.
I designed the reflector to use a pcboard to connect the high current Pogo pins to the 3mm banana jacks, eliminating a bunch of parts from the original design.
The base, rotor supports and detent assembly were redesigned to make 3D printing easier and stronger while still keeping the functionality and look of the original. The input box to the rotors was designed to use the same output pcboard and contacts as the rotors for simplicity.
The main rotor support shaft and the axles for the rotors, input box, and reflector are designed to be made from sections of nesting brass tubes that are soldered together using 3D printed assembly aides. This will eliminate the need to turn a lot of brass on a lathe and save on the amount of brass that will be needed.
The rocker and ratchet drivers were redesigned to make 3D printing easier, make them stronger, and make the use of off the shelf torsion spring possible. I also modified the area where the key will press on the rocker to allow the three rows of keys to have the same travel.
One of the more difficult things to research was the power switch. But by studying multiple photos and wiring diagrams, I designed my version that looks good will function the same as the original. It is constructed from 3D printer parts, threaded thermal inserts and brass hardware. The spring shorting contact will be made by pressing a piece of brass sheet between 3D printed dies. I will most likely need to iterate the design of the dies to allow for spring back after forming.
I will be making the case wrapper and lid out of 2mm (0.080") thick aluminum.
The lid will be formed around a buck to get the shape right. I will be CNC milling the holes and welding the sides on using the buck to keep things in shape.
The lid assembly was another interesting bit of detective work, but I think my version will hold up.
The power selector switch design I settled on will be 3D printed of course. I think the detent for the switch positions is the only questionable part but there are multiple options on how to redo it if I need to.
The spring loaded hold down catches were a fun bit of design but should work well. It is just two 3D printed parts and standard hardware, including an M2 shoulder screw with a bit of brass rod pressed in.
One of my favorite bits is the the light baffle plate, just because it looks so cool.
For the battery box I plan on using 18650 Lipo batteries with appropriate charging and regulating circuits.
And of course no Enigma would be complete without the wooden box to house it in.
The lid stay that holds the lid up in 2 positions (I think the lower position was used to shad the lamp read outs in bright conditions) is my best guess at sizing and along with the front door guides will be made out of aluminum. I found a replica of the lid latch on eBay and will be purchasing it.
For the Instruction sheet I plan on printing the text out on water slide decal paper to transfer to a Styrene sheet. The Enigma Badge will be 3D printed and filled with blue enamel. The extra lamp holder will be 3D printed as well.
The box itself will be made with blind finger joints I designed that can be mill/routed from one side.
