Wall Drawing Robot, Open Source
The robot can draw a picture on a wall
I name it is "Fumik"
Public Chat
Fumik will help us to draw a decor picture on wall easier than ever!
The robot can draw a picture on a wall in size up to 5 meters in width and 3 meters in height. It is hung on a wall, traverses around to draw pictures, looks like a jellyfish is swimming. Fumik is an easy step to learn about robotics and make art work with it.
In August 2021, I got an idea to make a robot be able to draw pictures on a wall. After many days researching, designing, and programming, I finally finished a robot that could draw any pattern on a wall.
My key-point in design is using general parts to make robot, so end-users can easily renew parts if repairing is needed. Body frame, motor, bolts and nuts, … are all easily found on the market. Main controller is well-known PCB Arduino Mega compatible with CNC Shield to control two stepper motors that allow robot can traverse by belt.
  • 1 × Arduino Mega 2560
  • 1 × cnc shield
  • 1 × SD card module
  • 1 × Stepper motor
  • 1
    Step 1: Part List to Prepare
    Arduino Mega 2560 x 1pc
    CNC shield x 1pc
    Power supply PCB x 1pc
    SD card module x 1pc
    Stepper motor (traverse) x 2pcs
    Gear (for belt) x 2pcs
    Stepper motor (pen) x 1pc
    Belt x 2pcs
    Base x 1set
    Bolt, nuts (various)
    Software
    Arduino IDE/ Corel draw/ Microsoft excel
  • 2
    Step 2: Install the Robot - 1st Layer
    The first layer is used to install Arduino, CNC shield, power supply.
  • 3
    Step 3: Install the Robot - 2nd Layer
    The second layer will be installed motor, SD card.
    Stepper motor shaft will attachment gear; and (black) blank wheel will be shifted (manually) to keep the belt always contact with the gear.
View all 9 instructions
