This project is a 3D printed support for wireless headphones that, also, allows to charge them when they are hanged.
soporte_cascos2.FCStdfcstd - 132.29 kB - 03/11/2022 at 20:54 |
soporte_cascos.FCStdfcstd - 67.86 kB - 03/09/2022 at 21:11 |
First I made the electric contacts for the headphones. For that I used copper tape.
First I applied it on the top; then I did several cuts, spaced 1 centimeter each, and bent them to form an electrode in the lateral. It doesn't touch my head because the headband has a piece of foam.
To avoid problems with the polarity, I added a diode bridge. Unfortunately, that meant that the output voltage would be about 1.4 volts less that the input, so I also added a voltage regulator. This allowed me to use a 12 volts power supply while feeding 5 volts to the headphones charger.
The next step was to design a support where to hang the headphones with two electrodes that would make contact with the headband. I used FreeCAD for that.
The file can be downloaded from the gitlab repository.
