Now I have to write some code. After some thought, it would be best if I had the following control
options:
- set level 1
- set level 2
- set level 3
- ventilate for 30 minutes
I noticed that 100ms is not enough to press the button. With a value of 500 ms, pressing the keys works stable.
The following is the ventilation level 2 code as an example:
// STAGE 2
On stage2 do
// 4 X CLICK DOWN
Pulse,14,1,500
gpio,14,0
Pulse,14,1,500
gpio,14,0
Pulse,14,1,500
gpio,14,0
Pulse,14,1,500
gpio,14,0
Pulse,14,1,500
gpio,14,0
// 2 X CLICK UP
Pulse,12,1,500
gpio,12,0
Pulse,12,1,500
gpio,12,0
//RESETGPIO
gpio,12,0
gpio,13,0
gpio,14,0
endonNow I can integrate the whole thing into my smart home and control it as I like. Unfortunately, I
haven't received the VOC sensor from Aliexpress yet, so I have to wait with the VOC-controlled
ventilation.
