Connect the 3.5mm connector to the RTL8722 board following the diagram.
AMB23 Wiring Diagram:
As RTL8722DM MINI has a built-in microphone on the board, there is no need for any external microphone.
2
Compile and Upload example
Open the example, “Files” -> “Examples” -> “AmebaAudioCodec” -> “OutputSineWave”.
Upload the code and press the reset button on Ameba once the upload is finished. Connect a pair of wired headphones to the 3.5mm audio jack and you should hear the generate single sinusoidal tone.
3
More References
Please visit the following websites for more details about the board & other examples:
