Another short test. I took one of my FDM 3D prints and applied aluminum tape to the outside surfaces. The resulting part doesn't look 3D printed at all, or even like plastic, it is even cold to the touch.
I then did a chemical blackening and weathering pass. It is much more aged than what is on the TV show, so I might try again but only use acrylic paint to darken the aluminum.
