I have been updating things recently...
If you get board and would like some moderate source on the Relay Cape, please visit here: silver2row/BBBW_RELAYCAPE: More Source for the Beagleboard.org BBBW and RelayCape (github.com) .
Here too: BeagleBoard.org BeagleBone Relay Cape — BeagleBoard Documentation
If that source from docs.beagleboard.org does not work to your liking, please just contact me. I am sure the two of us can make it work for the BBB or other am335x styled SoC board from beagleboard.org, and this Relay Cape.
Hello,
uname -r: 5.10.100-ti-r40
cat /etc/dogtag: BeagleBoard.org Debian Bullseye IoT Image 2022-03-12
Please see these ideas:
git clone https://github.com/mvduin/sysfs-gpio
1. Once you get the source or write your own, type make in /sysfs-gpio to create your project but please add your file to the Makefile for compilation.
git clone https://github.com/mvduin/overlay-utils
1. This lib. has the BBORG_RELAY-00A2.dtsi to be compiled into a .dtbo for use in /boot/uEnv.txt.
2. Once compiled with make, please add it to your /boot/uEnv.txt file and reboot your machine, i.e. the BeagleBone Black or other family board.
and this source for use with the lib:
#include "sysfs-gpio.h"
#include <stdio.h>
#include <unistd.h>
unsigned int mSeconds = 5000000;
int returnCode;
int main()
struct Gpio gpio = GPIO_INITIALIZER;
gpio_open_output( &gpio, "/dev/gpio/relay-jp3", false );
while (1) {
gpio_is_output( &gpio );
gpio_write( &gpio, false );
returnCode = usleep(mSeconds);
gpio_write( &gpio, true );
gpio_close( &gpio );
return 0;
You may also need a script that is located in /etc/udev/rules.d/ for use with accessing GPIOs without root permissions needed.
Here is the location of that file and you can call it: 80-gpio-noroot.rules
Once this file has been added, please reboot your system or use this command and it should work if we are lucky: sudo udevadm control --reload-rules
It is located here online and I will show it below also: https://github.com/beagleboard/customizations/blob/master/etc/udev/rules.d/80-gpio-noroot.rules
Here is the source:
# /etc/udev/rules.d/80-gpio-noroot.rules
# ReWritten by: Matthijs van Duin
# Corrects sys GPIO permissions on the BB so non-root users in the gpio group can manipulate bits
SUBSYSTEM=="gpio", ACTION=="add", \
RUN+="/bin/chgrp -R gpio '/sys%p'", \
RUN+="/bin/chmod -R g=u '/sys%p'"
SUBSYSTEM=="subsystem", KERNEL=="gpio", ACTION=="add", \
RUN+="/bin/chgrp gpio '/sys/class/gpio/export' '/sys/class/gpio/unexport'", \
RUN+="/bin/chmod g=u '/sys/class/gpio/export' '/sys/class/gpio/unexport'"
That should get you up to speed on this neat C/C++ lib. I found for use with the RelayCape, am335x processors from TI, and the Beagleboard.org family of boards.
Seth
silver2row
