Rotary Actuator is an open source rotary actuator built using the Clock Actuator included in the inexpensive and easily available Clock Movement.
Actuator specifications are maximum angle: ±20 °, driving voltage: 3.3 or 5V, coil resistance: 230 or 540 ohm each.
