more keys, better screen, better brains, more usable....
The original Clicker aimed more at being small than being usable. it was based around 50 buttons, and had an arrangement based on the planck 40% layout. with the new screen being wider, that gives us more space for buttons, and even with a slight bump in size, you can fit 80 keys into the space below the screen
With a bit of sniffing around at keyboard layouts, it becomes clear that 80 keys is a nice number. if you take a standard 'tenless' keyboard layout (with the numberpad whipped off) that uses 88 keys
the top row can be moved onto key modifiers, so a simple fn key and the standard number keys can work for the F keys. That saves 16 keys from the off, and we now have 8 too many :)
Now to fit and format them in a more sensible way........
