Music is divided into 7 frequency spectrums:
- Sub-Bass: 16-60Hz
- Bass: 60-250Hz
- Lower Midrange: 250-500Hz
- Midrange: 500Hz-2kHz
- Higher Midrange: 2-4kHz
- Presence: 4-6kHz
- Brilliance: 6-20kHz
Generally speaking, an increase of 10dB roughly corresponds to the perceived doubling of intensity
Max output voltage of a 3.5mm jack doesn't seem to have a standard limit, will have to figure it out experimentally
