- Got Case code and datasheet link for all resistors and caps
- using SOIC-14 footprint for LM324 op amp
- Drafted all filters onto KiCad schematic with correct footprints for all components
- Audio Input - will use mono audio input, male & female connectors to get the audio signal, will use a switch to choose between the 2 sources
