I tried it out with pegboards, and it worked great! Simply weave the el wire through the holes in the pegboard and create simple shapes.
![](https://cdn.hackaday.io/images/1722121654382707254.jpg)
Then turn off the lights and turn on the EL wire.
Thinner EL wire works better, you can fit more through each hole that way.
![](https://cdn.hackaday.io/images/5074751654382767308.jpg)
