The following research questions need to be addressed before detailed design can be commenced.
- Ideal airfoil profile for wind turbine.
- Median Wind Speed in my location (Southern Tasmania) for peak efficiency.
- Turbine RPM at this speed
- Appropriate Brush less motor that can be direct driven or driven using off the shelf gear box.
