As with my Sol-20 project, the keyboard encoder is expecting 5V while the Raspberry Pi 4 operates at 3.3V. So to overcome this I purchase a Voltage-Level Shifter Module from Amazon. Here is what it looks like.
I am using the Sol-20 header on the encoder and the pinout looks like this.
So here is how I wired the keyboard. Note that for the exception of +5V and GND lines which are wired to the 3.3V side or the level shifter, all of the other connections are wired to the 5V side.
Keyboard Encoder | Raspberry Pi | Description |
+5V | 5V | Power |
GND | GND | Ground |
D0 | GPIO5 | Key 0 bit (low) |
D1 | GPIO6 | Key 1 bit |
D2 | GPIO12 | Key 2 bit |
D3 | GPIO13 | Key 3 bit |
D4 | GPIO19 | Key 4 bit |
D5 | GPIO16 | Key 5 bit |
D6 | GPIO26 | Key 6 bit |
D7 | GPIO20 | Key 7 bit (high) |
STROBE | GPIO4 | Key ready on falling edge. |
The display has the following pinouts.
All of the following connections are wired to the 3.3V of the level shifter.
Display Module | Raspberry Pi | Description |
3.3V | 3.3V | Power |
data | GPIO21 | Data Pin |
select | GPIO22 | Register Select Pin |
clock | GPIO23 | Clock Pin |
enable | GPIO24 | Chip Enable Pin |
reset | GPIO25 | Reset Pin |
Next step, mount everything into the case.
