I created a template to cut out the "in"side panel pieces for the MCM/70
![](https://cdn.hackaday.io/images/8937411653612870236.png)
frame. The outside line represents the side panels as printed, while the inside outline is 3 mm smaller and is used to make an inner frame to support the top panels. Holes indicate positions where screws (#6 x 3/4 inch) will be used to attach the printed side panels to the inner frame (black dots), and attach flanges for 1/2 inch doweling to the inside frame (#6 x 1/2inch screws). I laser cut the template from a scrap of acrylic I had lying around to use as a positioning guide for the screw holes.
![](https://cdn.hackaday.io/images/7798911653614401942.jpg)
Then I laser cut four of the smaller pieces from 6 mm plywood.
![](https://cdn.hackaday.io/images/1456151653613560850.jpg)
I designed and printed six flanges to anchor 1/2 inch dowels.
![](https://cdn.hackaday.io/images/28301653613750218.jpg)
Then I glued two panels together for each inside frame and mounted the flanges based on the template.
![](https://cdn.hackaday.io/images/196201653614529570.jpg)
The dowels were cut so that the width of the machine from the outside edges of the inner frames is exactly 13.25 inches just as it is in the original. I attached the printed side panels to the inner frame pieces and inserted the dowels.
![](https://cdn.hackaday.io/images/507881653614780471.jpg)
So I now have a solid frame to which I will mount the rest of the MCM/70 components.
