Choosing a 3 axis machine
Looking for project specific recommendations...
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
I need to select the best tabletop CNC machine or laser engraver for use making holes (in a precise pattern) in phenolic boards for mounting various controller boards inside of e-boxes. I assume that with three axis control this should be a pretty basic task. I have been looking at the Vevor line, but the reviews are mixed and I can't find any particulars on compatible programming software, and I am by no means locked in to that choice. I want to be sure that whichever machine we choose is easy to program with readily available software and can be tooled effectively to drill/cut holes, and robust enough for repetitive production. Not huge quantities, but certainly not one offs. Any and all input is greatly appreciated!
Thanks so much :o)
