• LOG 1
    Arnov Sharma • 04/01/2022 at 04:41 • 0 comments
    MAKING THE BREADBOARD EDITION
    Before getting started, I prepared a simple Attiny85 Setup that consist of an Attiny Connected with a Buzzer and one LED.
    I followed the below schematic for connection and made a Breadboard edition first.
    I then programmed the attiny85 with my Arduino as ISP Programmer just by putting the attiny85 onto the IC Socket and flashing the MCU with the following sketch-
    #define speakerPin 0
    #define ledPin 2
    void setup() {
            pinMode(speakerPin, OUTPUT);
        pinMode(ledPin, OUTPUT);
        randomSeed(analogRead(0));
    void phrase1() {
            int k = random(1000,2000);
        digitalWrite(ledPin, HIGH);
        for (int i = 0; i <=  random(100,2000); i++){
                    tone(speakerPin, k+(-i*2));                  delay(random(.9,2));                 }     digitalWrite(ledPin, LOW);       for (int i = 0; i <= random(100,1000); i++){
                    tone(speakerPin, k + (i * 10));                  delay(random(.9,2));                 }
    void phrase2() {
        digitalWrite(ledPin, HIGH);      for (int i = 0; i <= random(100,2000); i++){
                    tone(speakerPin, k+(i*2));                  delay(random(.9,2));                 }     digitalWrite(ledPin, LOW);       for (int i = 0; i <= random(100,1000); i++){
                    tone(speakerPin, k + (-i * 10));                  delay(random(.9,2));                 }
    void loop() {
            int K = 2000;
        switch (random(1,7)) {
                    case 1:phrase1(); break;
            case 2:phrase2(); break;
            case 3:phrase1(); phrase2(); break;
            case 4:phrase1(); phrase2(); phrase1();break;
            case 5:phrase1(); phrase2(); phrase1(); phrase2(); phrase1();break;
            case 6:phrase2(); phrase1(); phrase2(); break;
        for (int i = 0; i <= random(3, 9); i++){
                    digitalWrite(ledPin, HIGH);          tone(speakerPin, K + random(-1700, 2000));                  delay(random(70, 170));          digitalWrite(ledPin, LOW);                   noTone(speakerPin);                 delay(random(0, 30));                 }     noTone(speakerPin);             delay(random(2000, 4000));     //(1000, 2000)
