MAKING THE BREADBOARD EDITION
Before getting started, I prepared a simple Attiny85 Setup that consist of an Attiny Connected with a Buzzer and one LED.
I followed the below schematic for connection and made a Breadboard edition first.
I then programmed the attiny85 with my Arduino as ISP Programmer just by putting the attiny85 onto the IC Socket and flashing the MCU with the following sketch-
#define speakerPin 0 #define ledPin 2 void setup() { pinMode(speakerPin, OUTPUT); pinMode(ledPin, OUTPUT); randomSeed(analogRead(0)); } void phrase1() { int k = random(1000,2000); digitalWrite(ledPin, HIGH); for (int i = 0; i <= random(100,2000); i++){ tone(speakerPin, k+(-i*2)); delay(random(.9,2)); } digitalWrite(ledPin, LOW); for (int i = 0; i <= random(100,1000); i++){ tone(speakerPin, k + (i * 10)); delay(random(.9,2)); } } void phrase2() { int k = random(1000,2000); digitalWrite(ledPin, HIGH); for (int i = 0; i <= random(100,2000); i++){ tone(speakerPin, k+(i*2)); delay(random(.9,2)); } digitalWrite(ledPin, LOW); for (int i = 0; i <= random(100,1000); i++){ tone(speakerPin, k + (-i * 10)); delay(random(.9,2)); } } void loop() { int K = 2000; switch (random(1,7)) { case 1:phrase1(); break; case 2:phrase2(); break; case 3:phrase1(); phrase2(); break; case 4:phrase1(); phrase2(); phrase1();break; case 5:phrase1(); phrase2(); phrase1(); phrase2(); phrase1();break; case 6:phrase2(); phrase1(); phrase2(); break; } for (int i = 0; i <= random(3, 9); i++){ digitalWrite(ledPin, HIGH); tone(speakerPin, K + random(-1700, 2000)); delay(random(70, 170)); digitalWrite(ledPin, LOW); noTone(speakerPin); delay(random(0, 30)); } noTone(speakerPin); delay(random(2000, 4000)); //(1000, 2000) }
