Weather Proof Box for the Machine Based Unit
A project log for Long Range Machine Control System
LoRa + ROS Full Duplex Peer to Peer Data Transceiver Array with Onboard High Precision Satellite Positioning
goat-industriesGOAT INDUSTRIES • 09/24/2022 at 12:11•0 Comments
Fancy custom made stainless steel panels were drawn up in LibreCAD and ordered from my local laser cutting factory. Files are available here: https://github.com/paddygoat/quadROSbot_2022/tree/main/Enclosure . These allow not only ethernet connection, but USB and HDMI ports for debugging of the Pis on the machine if necessary. If deployed to Mars, Martians could use them for watching Netflix.
