Since i don't want to put SSID and Password in the code I've made code to handle the AP mode, and let the user configure the SSID and password without code.
I have also used SPIFFS file system to host some Html and CSS, to make UI nice.
Finally added OTA to handle over the air updates so I don't need to link the Wemos to PC with a cable (at least when no debug Is needed).
Giulio Pons
