Assembly of parts
Next, I show you some images of the assembly.
Soldering
Protecting the board in a box
The prototype is finished
Test
Generating a PWM signal: This example requires a setpoint and the PWM signal is generated automatically.
Analysys
Generating a control PWM signal from a PIDController:
Setpoint: VBattery = 4.95 volts / VR5 = 2, 2 volts / ADC = 3003 ADC.
We can appreciate, here the PID controller, generates many duties cycles.
Measured frequency = 30 kHz
VR5 = 2,2 volts, duty cycle = 11%
VR5 = 1,99 volts, duty cycle = 12%
VR5 = 1,6 volts, duty cycle = 21%
VR5 = 1,3 volts, duty cycle = 24%
VR5 = 1,13 volts, duty cycle = 48%
VR5 = 0,9 volts, duty cycle = 91%
