TinyProbe - Logic Probe based on ATtiny13A
TinyProbe - Logic Probe based on ATtiny13A TinyProbe is a very simple 5V logic probe for TTL and CMOS logic based on ATtiny13A. The probe can detect high (HI), low (LO), floating (FL) and oscillating (OS) signals and displays them via four LEDs.
Project Video (YouTube): https://youtu.be/mwY1OOxqLTI
Design Files (EasyEDA): https://easyeda.com/wagiminator/attiny13-tinyprobe
Hardware
The basic wiring is shown below:
GND must be connected to ground of the test board, VCC to 5 Volts. In order to keep the device as simple as possible input protection has been dispensed with.
#Software
After setting up the GPIO pins, the ADC and the pin change interrupt, the tests are carried out in the main loop.
Checking the TTL / CMOS Selection Switch
First the position of the TTL / CMOS switch is queried. Although this switch is connected to the RESET pin of the ATtiny, it does not trigger a RESET, as the voltage on the pin never drops below 40% VCC due to the voltage divider. Depending on the switch position, the voltage is VCC or VCC / 2. The threshold values for the detection of a HIGH or LOW signal are set accordingly.
// define logic levels for TTL and CMOS at 5V #define TTL_LOW 164 // ADC value for 0.8V #define TTL_HIGH 409 // ADC value for 2.0V #define CMOS_LOW 307 // ADC value for 1.5V #define CMOS_HIGH 716 // ADC value for 3.5V // check logic level selection switch and set high/low thresholds accordingly valLow = TTL_LOW; // set low value for TTL valHigh = TTL_HIGH; // set high value for TTL ADMUX = 0b00000000; // set ADC0 against VCC ADCSRA |= 0b01000000; // start ADC conversion while(ADCSRA & 0b01000000); // wait for ADC conversion complete valSwitch = ADC; // get ADC value if (valSwitch < 768) { // if switch is on CMOS: valLow = CMOS_LOW; // set low value for CMOS valHigh = CMOS_HIGH; // set high value for CMOS }
Checking for Oscillations Two methods are used to determine if the signal on the PROBE is oscillating. First of all, the pin change interrupt is activated on the PROBE pin for 1 ms in order to detect high-frequency oscillation. To do this, the 100k resistor is activated as a pull-up (PB4 as output HIGH) so that a possible floating is not accidentally recognized as an oscillation. If there is an oscillation of at least 500Hz, the interrupt is triggered at least once in this millisecond, which sets the isOscillating flag. The isOscillating flag also contains a timer value (OSC_DUR), which is decreased with each loop pass, so that even brief oscillations are visible on the corresponding LED.
// check high frequency oscillation using pin change interrupt on probe line DDRB |= 0b00010000; // set pull pin to output (PB4) PORTB |= 0b00010000; // pull up probe line (to avoid floating) _delay_us(10); // wait a bit GIFR |= 0b00100000; // clear any outstanding pin change interrupt PCMSK = 0b00001000; // turn on interrupt on probe pin _delay_ms(1); // wait a millisecond (check >500Hz oscillation) PCMSK = 0b00000000; // turn off interrupt on probe pin // pin change interrupt service routine ISR(PCINT0_vect) { isOscillating = OSC_DUR; // oscillating signal on pin change }
In order to detect low-frequency oscillation, the isHigh / isLow flags are compared with the previous measurement. A change is evaluated as an oscillation, unless there is floating at the same time.
// check low frequency oscillation if (!isFloating && ((isHigh && lastLow) || (isLow && lastHigh))) isOscillating = OSC_DUR; lastHigh = isHigh; lastLow = isLow;
Checking for Floating
In order to recognize whether a FLOATING signal is present, the input is measured once with an activated 100k pullup (PB4 HIGH) and once with an activated 100k pulldown resistor (PB4 LOW). If the two measurements differ, the isFLOATING flag is set. For the subsequent measurement with the ADC, the 100k is deactivated by setting PB4 to INPUT.
// check if probe is floating by testing the behavior when pulling up/down isFloating = PINB; // get input values (line is already pulled up) PORTB &= 0b11101111; // pull down probe line _delay_us(10); // wait a bit isFloating &= (~PINB); // get inverse of input values isFloating &= 0b00001000; // mask the probe line (PB3) DDRB &= 0b11101111; // set pull pin to input (disable pull) _delay_us(10); // wait a bit
Checking the Logic State
In order to recognize whether there is a HIGH or LOW signal at the PROBE, the applied voltage is measured with the analog to digital converter (ADC) and compared with the threshold values selected based on the switch position. The isLow and isHigh flags are set accordingly.
// read voltage on probe line and check if it's logic high or low ADMUX = 0b00000011; // set ADC3 against VCC ADCSRA |= 0b01000000; // start ADC conversion while(ADCSRA & 0b01000000); // wait for ADC conversion complete valProbe = ADC; // get ADC value isHigh = (valProbe > valHigh); // check if probe is logic high isLow = (valProbe < valLow); // check if probe is logic low
Setting the LEDs
Last but not least, the indication LEDs are set using a simplified Charlieplexing algorithm. If the isOscillating flag is set, the integrated timer is also decremented.
// set the LEDs (charlieplexing) PORTB &= 0b11111000; // switch off all LEDs if (isFloating) PORTB |= 0b00000100; // if probe is floating: set FL LED else { // if not floating: if (isLow) PORTB |= 0b00000010; // if probe is low: set LO LED if (isHigh) PORTB |= 0b00000101; // if probe is High: set HI LED if (isOscillating) { // if probe is oscillating: PORTB &= 0b11111011; // set OS LED without interfering PORTB |= 0b00000001; // with HI/LO LED isOscillating--; // decrease OS LED timer } }
Compiling and Uploading
Since there is no ICSP header on the board, you have to program the ATtiny either before soldering using an SOP adapter, or after soldering using an EEPROM clip.
The AVR Programmer Adapter can help with this.
If using the Arduino IDE
Make sure you have installed MicroCore.
Go to Tools -> Board -> MicroCore and select ATtiny13.
Go to Tools and choose the following board options:
Clock: 1.2 MHz internal osc.
BOD: BOD 2.7V
Timing: Micros disabled
Connect your programmer to your PC and to the ATtiny.
Go to Tools -> Programmer and select your ISP programmer (e.g. USBasp).
Go to Tools -> Burn Bootloader to burn the fuses.
Open TinyProbe.ino and click Upload.
If using the precompiled hex-file
Make sure you have installed avrdude.
Open a terminal.
Navigate to the folder with the hex-file.
Execute the following command (if necessary replace "usbasp" with the programmer you use):
avrdude -c usbasp -p t13 -U lfuse:w:0x2a:m -U hfuse:w:0xfb:m -U flash:w:tinyprobe.hex
If using the makefile (Linux/Mac)
Make sure you have installed avr-gcc toolchain and avrdude.
Open the makefile and change the programmer if you are not using usbasp.
Open a terminal.
Navigate to the folder with the makefile and sketch.
Run "make install" to compile, burn the fuses and upload the firmware.
If you guys really want to order PCB for this tiny probe don't worry I have all the reuired files for you, just download or edit them and order PCB for this tinny probe.
I suggest you to please try JLCPCB.com to order your PCB
CIRCUIT DIAGRAM
This is the link of circuit diagram https://oshwlab.com/wagiminator/attiny13-tinyprobe
CUSTOM PCB
This is the link to to download or edit the gerber file of tiny PROBE proejct https://oshwlab.com/wagiminator/attiny13-tinyprobe
BOM
ID Name Designator Footprint Quantity
1 MSK-11027 KEY1 SW_SMD_MSK-11027 1
2 470R R3,R5,R4 0603 3
3 10k R2,R1 0603 2
4 100k R6 0603 1
5 HI LED2 LED0603 1
SMT Assembly service of JLCPCB.com is cherry on top now get your PCB fully assembled and save your time and money Select components for your PCB from there Parts Library of 200k+ in-stock components they are offering $27 valued New User coupons & $24 SMT coupons every month $8.00 setup fee, and $0.0017 per joint
Now no need to order components separately for you PCB and get free from stress of soldering them on PCB just try PCB SMT assembly service and get you PCB with components pre assembled and ready for the project
👉 Try PCBA service of JLCPCB.com and save your time and money, get PCB ready for project, 200K+ components in library of JLCPCB.com as well as 3rd party parts to choose from. Assembly will support 10M+ parts from Digikey, mouser
👉 $27 valued New User coupons
👉 $24 SMT coupons every month
For more detials & offers please visit JLCPCB.com
Click here to visit JLCPCB.com
