Version 3 has arrived! It looks just like version 2 on the outside, but it has a few big changes. These changes has made it more robust and made the display much more reliable.
The new version now uses a Esp32-S3 DevKit from Expressif. This DevKit has all of the I/O pins I needed without the I2C port expansion chips. The CPU board uses fewer SMD components overall as well. I replaces the SMD resistors and transistors for driving the digits with through hole components.
The changes to the code includes
- Migrated to version 5.4 IDF build tool.
- Made the menus even more object oriented
- Expanded the JSON messaging
- Added rudimentary Home-Assistant support
- Integrated support for the Govee H5100 bluetooth temperature sensors.
The display board has not changed at all.
The code can be found here: https://sourceforge.net/p/nixiestat-3/code/ci/master/tree/
