By using a webcam and libraries such as OpenCV, X11, et cetera, Gestro is able to successfully translate hand gestures performed by users into commands that performs certain operations including, but not limited to, increasing or decreasing the system's volume, move, minimise, or close windows, and mouse clicks. Gestro is designed to be displayed using a Qt application on the users' Linux system running the Ubuntu distribution.
Gestro is designed to be used on Linux PCs running the Ubuntu distribution. In particular, it was tested and found to be running perfectly on PCs running Ubuntu 18.04 LTS.
Prerequisites:
A PC running Ubuntu.
A webcam.
Gestro requires the following tools and libraries to run (other versions are not tested):
X11
Qt 5
OpenCV 4.5.5
libasound2-dev
Boost Unit Test Framework
Wong Tian Jie
TinHead
Matheus Carvalho
Swoosh Mihu
ls1911
