The case is designed to house the image sensor and other components.
The following items are stored in the case.
- Image sensor
- Raspberry Pi 2
- Main board
- Sensor for acquiring shutter movement
- Battery
- Power switch
- 2 LEDs
- Dip switch
The specifications of the device itself, which will be placed inside, have not yet been clearly decided, but I will make a mock-up and check it as we finalize the design.
After three prototypes, I will proceed with development based on the shape shown in the photo.
