I received my packaging materials today, so I packed up and shipped one to Warsaw for the student I mentioned a couple of updates ago.
This is what they will get:
I had to break it down a little for shipping (I included mounting hardware):
So it would fit in a 100x25x35cm box (weight 7kg):
I used soooo much bubble wrap - I hope it arrives in good condition.
UPDATE
They received it in good condition. Hopefully setup will go ok. I really want this to be easy to setup and use, so this is a good test.
UPDATE
After fixing a few connections that came loose in shipping, it seems to work and is mounted. Now it's up to the birds. Kudos to the student for some excellent troubleshooting and fixing.
