There are a few things I want to improve on the VMFB, but don't really have the time to knock out right now. The current design works well enough and has worked reliably for a few months with minimal supervision.
I'm trying to get to Stage 5 before May. Then I will be more motovated to do the following:
- port the software to a lower-power solution
- make the dispense pathway impossible to jam
- move the PIR sensor to the camera arm
- make deposit sensor placement easier
- make the deposit pathway shorter
