Producing something that convincingly looks like a first look at a look inside a gargantuan black hole that is not only swallowing stars but which might also reveal a naked singularity, in addition to a traversable wormhole is quite simple. First, substitute an ordinary LED flashlight for the "petawatt class laser capable of continuous operation" described in the instructions, i.e., in order to also satisfy the requirement that the project makes use of some kind of electrical components, even if it doesn't blink. Then use a 3-d printed gear from another project as an "optical diffuser" instead of the 1000 kilo-ton obsidian block which was previously suggested as a means of sorting entangled photons. If you can't obtain a "genuine host control" unit from "the Delos Corporation", ideally an unprogrammed "boron nitride doped diamond holographic processor", then just use any crystal or acrylic sphere, according to availability. Lastly, a pair of crystal earrings (even though only one is in use) makes an ideal secondary subspace evanescent field processor, that at least in principle - COULD ACTUALLY WORK as a single q-bi quantum processor.
In the meantime, I hope you enjoyed this NON PHOTOSHOPPED sneak preview of some kind of imaging provided by a not yet built future "electron telescope". For now, actually building ORAC is a bit beyond the scope of the budget for this project, but building it and documenting it was a lot of fun.
glgorman
