Hi there!
This is my first project that I post on hackaday.
Example of working
Attiny13 have onboard 1 kBytes of Flash memory.
Program you see on video use only 882 byte of memory. It means that you can write message 100+ char long. If you off tests of pixel moving and line size of code 522. Almost ~500 chars text.
Attiny13 drive 20 LEDs by 5 pin;s. Let's look at the scheme:
This is "charlieplexing" you can read more on wikipedia.
In every moment of time you can only "on" 2 or 3 LEDs. What you need to do for switching "on" all leds? You must switch on every LED for small part of time.
You can see working version in commit "01940c8". I plan optimize code: remove duty cycle delays and use timers and sleep sequential. Work in progress.
Also on Github you can download all source and schematics with PCBs design. Also BOM list.
Alexander Ryzhkov
Albert Gonzalez
