as you can see, there's a deviation of the line, I was pushing too hard and the vise holding plate of the drill has turned instead of the aluminium plate I was machining.
As it's the first pass, it's not very important, but from then, I had to hold the base plate with the left hand while turning the aluminium plate with the right one.
