Another of these 5 mm thick aluminium L is going to be used, cut in two halves.
The 2 mm square tube is too weak. That'll be stronger.
Drilling, taping, as you can see, stainless steel screws are used.
It's nice to have a big jaws vise on the bench.
M3 screws in an 5 mm thick plate, it'll do, but it was close to the disaster.
As the L shape are bigger than the 30 mm square tube, the alignement with the rear part of the build is perfect and easy now.
[zit] Olivier Gade
