last pass
A project log for How to use an aerial 36 inches lens
the different steps involved to shoot with an aerial photographic (enormous) lens when you don't have the airplane to hold it
zit-olivier-gade[zit] Olivier Gade 04/27/2022 at 08:550 Comments
Finally I can see the end !
It's been very long to drill that hole, hours... but could have been much faster : I didn't think of changing the drill speed and it was at around 500 RPM only !
