adjusting the rear of the board
A project log for How to use an aerial 36 inches lens
the different steps involved to shoot with an aerial photographic (enormous) lens when you don't have the airplane to hold it
zit-olivier-gade[zit] Olivier Gade 04/27/2022 at 14:390 Comments
Now it will be lightproof, with the help of a small piece of bicycle tire inner tube to realize a perfect fit (under the left blue arrow).
