As the speed was too slow to have the possibility to take pictures on a bright sunny day, the bungee needed to have more tension.
After a too violent trial with 300 mm off, it's about 200 mm shorter now and it will give a faster speed.
The tightening of the bungee is achieved with a Serfex clamping ring.
[zit] Olivier Gade
