Testing was successfully done!
- ✓ ESP32 flashing and Serial works
- ✓ Pressure Sensor works
- ✓ BMX160 works
- ✓ Buzzer Works
- ✓ Debug LED works
- ✓ Battery sense Pin ADC works
- ✓ Battery charging works incl. charging indicator LEDs!
- ✓ Reset and Event Button are running
- ✓ SD-Card works
The SD-Card Holder is pretty shitty and already kind of broke after a few times in and out. I created a 3D case which is about to be printed. With that case I can attach the device via the Wahoo connector to any bike.
I also wrote the code for data-logging to write the sensor data to the SD-Card. With this setup I can go out and collect data of different jumps and tricks on a bike which I then can throw into some TinyML processing tool like Edge Impulse or similar.
I still need to lean about machine learning on microntrollers.
