A do over for the holes for the line tracker. I filled them in with JB Weld SteelStik . I will file this down flush on the inside and re cut the holes so they are accurate and don't look like garbage.
Cut more accurate holes for the RGB LEDs, Peep the horrible holes for the line tracking
