Attenuation at low frequencies (50 - 100 kHz)
A project log for DIY 1.3 GHz FET Probe
An active scope probe with high-ish bandwidth and very low input capacitance
christophChristoph 10/09/2024 at 13:470 Comments
I was asked if the probe can be used below 100 kHz. So I took one of the older ones I had around and had a look at it with the scope.
Before:
After (modified):
Result table:
So with the larger input cap the attenuation at low frequencies is around -25 to -26 dB, as desired. However, input capacitance is somewhat larger (but still low - but I don't know how low exactly).
