The beginning
A project log for DIY 1.3 GHz FET Probe
An active scope probe with high-ish bandwidth and very low input capacitance
christophChristoph • 04/18/2022 at 22:22•1 Comment
Wolfgang designed his PCB in PCBExpress (I think), so I recreated his layout in KiCad. This was the result:
This was pretty small already, but was quite inconvenient for a couple of reasons:
I sent it to Wolfgang anyway, and it performed well. The next step was to improve the design a bit towards a tool that can be handled well, and that can be solderen into a circuit (for when lead inductance really counts). The SMA was swapped for a u.Fl, and so was the power supply input. Adding an RF shield wasn't so easy because the common, small, off-the-shelf parts all have four walls. I picked a small one that looked easy to modify, and came up with this:
This is the probe characterized on Wolfgang's page:
https://electronicprojectsforfun.wordpress.com/solder-in-probes/
Next log will be about assembly and will also contain a link to a repo with layout files and all that.
indigoredster wrote 04/19/2022 at 00:06 • point
Nice!!!!!!
