Ameba AMB21/22/23 boards are being used to connect to a Waveshare 2.9-inch e-Paper module for display.
The 2.9” active area contains 296 x 128 pixels and has 1-bit white/black full display capabilities. An integrated circuit contains a gate buffer, source buffer, interface, timing control logic, oscillator, etc… are supplied with each panel.
You may refer to the official 2.9-inch e-Paper HAT(D) datasheet to know more information about this module. Front view of the e-Paper Module:
Download the Eink zip library, AmebaEink.zip, at https://github.com/ambiot/ambd_arduino/tree/master/Arduino_zip_libraries
Then install the AmebaEink.zip. Open the “DisplayText” example in “File” → “Examples” → “AmebaEink” → “EinkDisplayText”:
Upload the code to the board and press the reset button after uploading is done. You will find these texts displayed on the board:
