So we previously couldn't connect the raspberry pi to my computer.
Problems/Solutions :
Pb: the raspberry couldn't connect to my 4G when the connection file was in the ssh folder created at the sd card root.
S: I put the file directly in the sd card root
Pb : When connected to 4G, the raspberry wouldn't connect to the computer. The connection wasn't allowed. When it was allowed the raspberry default password didn't work.
S: I directly configured the wifi when enabling ssh on Raspberry Imager (when you install all the files on the sd card aka when you're flashing). I also chose a user name and a password for the raspberry (still at the flashing stage). The new imager version requires that now. /!\ Apparently, you still have to put the wifi connection file on the sd after flashing it this way.
Pb : the connection would time out
S : Your pc and rby might not be on the same wifi, or you have bad connection.
Pb : a lot of command that I found on internet where in linux and not window langage, plus my ubuntu didn't no matter even after re downloading 234655 times on internet or the windows store.
S: Just follow this https://codedesign.fr/tutorial/wsl2-linux-sous-windows/ it's how to install it via the windows shell
