I scoped out some out some pressure sensors, and then choose a
20g-2 kg high precision resistance type thin film force sensor
its a generic disk type sensor.
After doing some research on "shake generators" i found that generators in the form factor (small) arent for sale sadly.
So i am gona build my own.
But building a smal form factor shake generator is almost a own project.
Thats why the first prototypes will use a button cell so i can test the rest of the sensors untill i get the generator working.
I also started to design the handle in FreeCad
