Alright, this is it. We’re live. I’m starting a project called BoxLambda. Here’s the run-down, copied verbatim from the README.md:
BoxLambda is an open-source project with the goal of creating a retro-style FPGA-based microcomputer. The microcomputer serves as a platform for software and RTL experimentation.
BoxLambda is a software-hardware cross-over project. The plan is to provide room for experimentation both on the FPGA RTL side and on the software side.
Key Goals
- Create a sandbox for experimenting with software and (FPGA) HW.
- Simplicity: It should be easy to jump in and do something: create, hack, tinker.
- It should be doable for a single person to develop a good understanding of the entire system, software and hardware.
- Deterministic Behavior: By design, it should be clear how long an operation, be it an instruction or a DMA transfer, is going to take.
- Single User/Single Tasking OS booting to a console shell.
- Create a Modular Architecture allowing for a mix-and-match of software and hardware components.
- Support for partial FPGA reconfiguration.
- Target Hardware is Digilent’s Arty-A7 and/or the Nexys-A7.
- The computer should support the following peripherals:
- Keyboard
- Mouse (optional)
- Joystick (optional)
- Serial port
- SD card storage
- VGA Display
- Audio output
- Sound and graphics should be sufficient to support retro-style 2D gameplay.
You can find the source code for BoxLambda on GitHub: https://github.com/epsilon537/boxlambda/.
Why?
Does the world need another retro-style computer? Probably not, but I do. I’m a software engineer and I’ve been studying FPGA development for about a year now, specifically for this project.
It’s an ambitious project and at least half of it (the FPGA half) is in a realm with which I have very little experience. I don’t know if the project will succeed. Maybe I’m too ambitious and too naive. We’ll see. This Blog will document the journey.
What’s up with that name, BoxLambda?
“Box”, as in, a physical box. “Lambda”, as in, an anonymous function, a software concept. It’s an attempt to convey that this project is both about hardware and software. Microsoft would have been a good fit too, but the name was taken.
Interesting Links
https://www.commanderx16.com : The Commander X16 is the 8-Bit Guy’s dream computer. This is the project that got me dreaming. I want to build a computer like this, but not exactly like this. I want to build my own.
OK, that’s enough for an introductory post I think. See you in the next one!
