if you want to test the new core unit, I've put the stl files on my gdrive:
https://drive.google.com/drive/folders/1kwc13bQUv-6axDW3g2RIkeYDfymdQTxG?usp=sharing
Important note:
The mount plate V2 is not compatible with the version 1 of the scanner. I've added a compatible version.
I've used PETG for the mount plate and PLA for the rest - all printed with a 0.4mm nozzle.
