This was probably the toughest part to figure out what I wanted to do. At first I thought I'd just make Braomar hard-wired to a wall adapter, but I didn't like the idea of a wire coming out of the base. I decided to make it battery powered. I thought about using a RC switch, but that would still drain the battery.
What I came up with was putting a reed switch in the base, and having it sit on a platform that magnetically sticks to the 9V battery in the center and has a magnet along the edge to operate the reed switch. When Glenn wants to turn Braomar on, he ritated the base and viola! Braomar turns on and does his light show.
scubabear
