I have designed this rectifier circuit using Schottky diodes capable of withstanding 15 amps. Perhaps it is an exaggeration but I prefer to be prepared for any surprise. The use of these diodes guarantees lower losses in the rectification process compared to more common rectifier units.
If you wish, you can now download the Gerbers Files and print the PCBs from the Files section.
In my case I made the connections quickly with cable connectors as shown in the photo and it went very well.
Having completed this stage guarantees to make the measurements and experiments that I want to do perhaps in the next week. I plan of course to post here the process and its results.
See you in a next Log!
