11STEP 11: INSTALLATION OF THE REST OF THE COMPONENTS OF THE YAW ASSEMBLY
Install part (I) inside the bearing. Insert this assembly inside the cavity for this purpose of the Central Body. Place the two Retaining Clips in their positions. Glue the plastic handle to the piece (I). This will make it possible to screw this Wind Turbine to a tripod or other device with a ¼ inch male thread.
note: In the video that I showed you above, the depth that I had designed to contain the bearing was incorrect. I noticed this doing the assembly. I decided to glue the bearing to the central body and didn't use the retaining clip :) In the STL file I uploaded for this piece this error is fixed.
I recommend making part (I) in metal at a local workshop or by yourself if you have the skills and tools. Although I don't think it can fail in the short term, I do think that in metal it would be much more resistant over time.
Units in mm
adriancubas
hello is there any upelate regarding the motor? Thanks
Hi, I am student of final year in mechanical engineering.And working on small portable wind turbine in final year project.kindly give the blade design specification on Q BLADE that I can work on this project
How is your project going? Has this helped you in your research? The files are ready. Any questions ask me. Cheers
Very nice project! do you have more details about the components assembly and eletronic assembly?
I am writing the steps. In a few days I will finish them. Stay tuned!!! Thanks for your comment
